Like Tree346Likes
Mugen MBX8
    Hide Wikipost
Old 05-31-2019, 05:05 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX8
Last edit by: E1 Diablo
E2025 - MBX8 Worlds Edition - April, 2019
MUGE0240: Wide Offset Wheel Hubs 1mm 2pcs; The 1mm wide offset wheel hubs will increase stability and cornering.
MUGE2146: Inline Front Uprights; The E2146 inline front uprights have smoother steering compared to the stock E2147 trailing front uprights and work great in high traction conditions. E2146 uprights can be used with both CVA and universal style driveshafts.
MUGE2168: -3mm Front Upright Arm; The -3mm front upright arm improves the initial steering response and make the vehicle more stable through the middle and exit of the corner.. The new upright arms also reduce bump steer and make the vehicle more predictable in bumpy conditions.
MUGE2235: 46T Spur Gear; The 46 tooth HTD spur gear provides a great balance of acceleration and top-end speed.
MUGE2252: 12T Pinion Gear
MUGE2254: 42T Conical Gear; The optional 12T bevel gear when used with the 42T conical gear will change the final drive ratio and increase acceleration.
MUGE2260: Center Joint Cup.
MUGE2261: Center Front Dog Bone (84.5mm)
MUGE2262: Center Rear Dog Bone (115mm); The front and rear-center dogbones for the MBX8 reduce friction from the stock universal driveshafts. Less friction will give the vehicle a more efficient drivetrain, increase acceleration, and provide more traction. The dog bones are lightweight, durable, and will increase traction.
MUGE2428: Rear Wing Stay +15mm; The +15mm wing mount has more adjustment and will help increase mid corner rotation and be more stable in high speed conditions.
E2021 - MBX8 1/8 Nitro Buggy Kit
Chassis:
The MBX8 chassis features a new design that improves traction and stability in bumpy conditions and on the exit of corners. The steering post are also keyed into the MBX8 chassis for easier maintenance.
Differential & drive train:
High Traction Differentials are included in the MBX8. The Mugen Seiki HTD provides increased acceleration, longer runtime, and more consistent handling. The HTD's also increase stability, traction, and improve handling in bumpy conditions. The HTD has a new larger volume diff cup to increase consistency during long main events. This makes it easier to time rhythm sections, better in bumpy and low grip conditions, helps to increase traction, and increases fuel mileage.
The new gearbox makes allows you to remove and service the differentials without detaching the suspension arm mounts. Easy access to the front and rear differential.
New straight cut 13T bevel gear & 44T conical gear. The new straight cut bevel and conical gears increase acceleration, runtime, and efficiency. A free and efficient drive train will also increase speeds while cornering.
Light weight one-piece wing mount:
The new lightweight one-piece wing mount lower the center of gravity. The position of the wing and wing mount is optimized to improve the performance of vehicle. The height of the wing mount is adjustable. This allows you to control the down force on the rear of the vehicle by simply raising or lowering the mount on the shock tower.
Light weight high down-force wing:
The new IFMAR legal wing is lightweight and provides amazing down force and cornering. The underside of the wing uses a new design to reduced weight and creates additional down-force.
Suspension:
New suspension mounts. The FF/FR/RF/RR are new for the MBX8.
The front and rear lower arms use a new impact resistant material for increased durability. The new arms are box-shaped and include arm stiffeners to reduce flex and increase durability. Adjusting the hardness of the lower suspension arms is now possible. This allows you to fine tune the steering and traction from track to track. CFRP plates will be released as an option part.
Center differential mount & plate:
The center differential mounts use a stiffer material and has a new top plate to reduce chassis flex and increases clutch bell, spur gear, and clutch bearing life. The reduced chassis flex also provides more consistent handling in all conditions. The top plate design also makes it easier to adjust the brakes and easier maintenance.
Enclosed Battery box and updated carbon fiber radio plate:
The MBX8 still uses a flat 2S Lipo or Life battery, but the receiver battery is now enclosed in a molded battery box. The battery box allows for quick and easy access to the battery. The molded box also helps protect the battery from hard impacts. The battery box is mounted to an updated carbon fiber radio plate.
Other new parts and upgrades:
Body, Clamping Servo Saver Nut, F/R Shock Towers, Front bumper, Front center and rear center universal joint.
Mugen Seiki MBX8 Manual
Print Wikipost
Old 12-03-2017, 02:22 PM
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Default Mugen MBX8
announced...
The NEW MBX8 has a lot to offer! More durable, more acceleration, more runtime, easier to work on, and lightweight. The new Mugen Seiki MBX8 buggy has been put to the tested and develop by the best drivers in the world. Soon you’ll be able to get your hands on the MBX8 Nitro Buggy. Coming late January 2018!
Part # E2021MBX8 Nitro Buggy Kit.
Here’s a look at some of the new features for the Mugen Seiki MBX8.
See More
No automatic alt text available.
Attached Thumbnails Mugen MBX8-24130128_10155868487199054_9081255071171338255_o.jpg
1/8 IC Fan is offline
Old 12-03-2017, 02:42 PM
werner sline's Avatar
cool ! can't wait to see what they improved !
i jump the electric version ( heavily modified ) and always like this chassis and transmission !
i hope they didn't make it weaker with lighter parts...
werner sline is offline
Old 12-03-2017, 04:58 PM
1/8 IC Fan's Avatar
Yeah, its going to be neat to see. Given how well the MBX7 is, what does Mugen Engineering and the Team drivers think the new platform needs.
Old 12-03-2017, 05:11 PM
just for fun : i sent mugen a mail, almost a year ago, showing them what i do with a mbx7 : they didn't bother to reply. i guess racers are their target, not funky crazy bashers ! adam drake did reply in one comment i made in his video. i love you adam !
1/8 IC Fan likes this.
Old 12-03-2017, 06:45 PM
Revolauncher's Avatar
Trader Rating: 15 (100%+)
The Drake likes to bash that Arrma Outcast! Mugen could improve diff access, maybe lighten it up a bit, that is about it for me...
saychz316 likes this.
Revolauncher is offline
Old 12-03-2017, 07:30 PM
1/8 IC Fan's Avatar
I know Robert has been testing it for a week or two.
Old 12-03-2017, 07:40 PM
R/C Tech Elite Member
I hope it comes with a battery box, split center mount and a significantly changed servo tray.
mlax is offline
Old 12-03-2017, 09:58 PM
Does it mean mbx8r is coming soon lol when mbx7 was released how long did it take to release Mbx7r?
J5137 is offline
Old 12-03-2017, 10:16 PM
Trader Rating: 40 (100%+)
A couple years.
BrakeTurnAccelerate is offline
Old 12-03-2017, 10:30 PM
1/8 IC Fan's Avatar
Mugen is not AE, haha.
AE cloned the MBX7R, then go out and release .1, .2 etc... like every year
Old 12-03-2017, 10:35 PM
Default New parts
aulin79 is offline
Old 12-04-2017, 06:47 AM
It's the old transmission ... there are no official photos.
mauro67 is offline
Old 12-04-2017, 07:05 AM
hairymuffin's Avatar
Trader Rating: 105 (100%+)
Tim said a few years ago that the split center diff mount didn’t give good support, so i put a mbx6 center diff mount in mine.
Motorman007 likes this.
hairymuffin is offline
Old 12-04-2017, 08:04 AM
Default Yes
Yes.. i found these parts in a new Mbx7r kit just purchased. My old kit had old one...
aulin79 is offline
Old 12-04-2017, 10:32 AM
Trader Rating: 24 (100%+)
When can we expect the ECO? anybody know what they've done historically? Few months?
dogbone418 is offline
